Tractor Talk Discussion Forum
Follow-up to :? about aux. hyd. on 1850 Oliver
Chris-se-ILL
07-18-2003 09:38:50
Rick, and all those that gave advice about hooking an auxiliary valve system to an Oliver 1850 (I posted the question about 1 week ago). I finally had time to go back and work on the tractor and I found my error. The aux. valve system WAS set up as a closed system and thus the oil would not circulate when the 3/8ths plug was inserted in the passage (I did have the return line hooked up, but with the closed system the oil would not return).
I replaced the "closed system" plug in the aux. valve body with an "open system" plug and now the valves work fine!
Thanks for the info and assistance!
Chris
Rick
07-18-2003 19:44:23
 Re: Follow-up to :? about aux. hyd. on 1850 Oliver in reply to Chris-se-ILL, 07-18-2003 09:38:50
sometimes the simplest little things can sure be fun. Glad it worked out for you. Rick
