Tractor Talk Discussion Forum
Clutch problem with David Brown 885
Chris
07-19-2003 18:05:43
Had this tractor for 12 years and it ran great until recently. It has the live pto, and the clutch doesn't fully disengage. It's really hard to get it into gear, and the pto only works when the tractor starts moving, not like before when the pto and hydraulics would kick in after letting the clutch out a bit but before the tractor moves. Is there anything I should check before I split the case?
nhboyd
07-21-2003 18:56:30
 Re: Clutch problem with David Brown 885 in reply to Chris, 07-19-2003 18:05:43
How much free travel at the clutch pedal do you have. should have 1 1/2 inches. adjust linkage to get this. If this dos'nt work you will have to split the tractor.
Chris
07-22-2003 06:42:15
 Re: Re: Clutch problem with David Brown 885 in reply to nhboyd, 07-21-2003 18:56:30
The pedal used to go right down to the running board, but I've since pulled it off the shaft and rotated it so now it doesn't even touch the board when it's down all the way. Damn, that's a job I wasn't looking forward to, a root canal would be more desireable
