Tractor Talk Discussion Forum
Adding water to battery charging
jCarroll
07-23-2003 07:06:22
My battery needs to be charged, and is also low on water.
Do you add the water, and then charge?
or
Charge the battery, and then top off the water?
Dave Wis
07-23-2003 21:36:47
 Re: Adding water to battery charging in reply to jCarroll, 07-23-2003 07:06:22
I work for one of the big three auto mfgr. in the lift truck repair shop of one of their assembly plants. One of my jobs is servicing the batteries in our electric fork lifts. The recommended procedure is, the electolyte should cover the plates prior to charging and topped off to the bottom of the fill hole after charging. The reason is, the electolyte expands as it heats from charging and if the battery is full cold it will bubble out. What evaporates from normal use is just water but what bubbles out is acid. Then when it is replaced with water the acid is diluted, not good for the battery.
willyz
07-27-2003 04:27:24
 Re: Re: Adding water to battery charging in reply to Dave Wis, 07-23-2003 21:36:47
I have a 36V battery on my forklift, the top of the battery had alot of acid build up. I cleaned it off and sprayed a terminal protector on it. When I opened the cell caps the fluid was below the plate tops and the battery needed charging. Are you saying that I should add some electrolyte and not just water? I know there is a proper way to handle these batteries and with the cost of replacements I'd like to get all the life I can out of this one. Any advise you can offer would be greatly appreciated.
ErnieD
07-24-2003 16:15:35
Good advice here
Jeff
07-23-2003 08:03:11
Add distilled water first...
then charge...
John Ne.
07-23-2003 10:17:54
 Re: Re: Adding water to battery charging in reply to Jeff, 07-23-2003 08:03:11
And, make sure its room temp, adding chilled water to a battery thats 180degrees, under the hood, can warp the plates, and probably kill it, it was a trick of the old road side gas stations that needed to make some quick sales. Same goes for adding really warm water to a freezng battery. John in Ne.
Roy in UK
07-23-2003 11:57:39
 Re: Re: Re: Adding water to battery charging in reply to John Ne., 07-23-2003 10:17:54
And....Don't over fill the cells
