Tractor Talk Discussion Forum
Any one have a problem with Tractor supplys premiu
Corkscrew
07-24-2003 05:08:46
I have a Kubota L4310 with HST. I need to change the hydraulic fluid and was going to use Tractor supplys premium hydraulic fluid instead of the expensive Kubota UDT fluid that the manual recomends. TSC's premium fluid lists that it is suitable as a replacement for Kubota UDT fluid. The thing I am worried about is that I have a friend that recently used TSC's premium fluid in a John Deere motor grader and is now having problems with the hydraulics leaking down when the unit gets hot. Has anyone else had any problems with this premium hydraulic fluid from TSC?
Thanks
Tom
07-25-2003 05:14:21
 Re: Any one have a problem with Tractor supplys pr in reply to Corkscrew, 07-24-2003 05:08:46
Don't be a typical tightwad, buy cheap lubricants and then cry around the coffee shop in a few years with the large repair bills that will follow. Get the recommended fluid.
tbear
07-24-2003 15:48:59
Your friend didn't use compatiable oil for his machine.All hydralic oil is not the same.You need to consult your manual or dealer to find out what hydralic oil to use for your machine.I have a bulldozer that requires hytran oil but my operator put another grade in it and the same problem occured whan mahine is cold hydralics worked fine but when it got worm it ran at 25% speed do to the incompatable oil.If in doubt buy better stuff
Robert in W. Mi
07-24-2003 13:24:24
You spent all that money on a Kubota, and now you want to put cheapo fluid in it?? How often do you plan to change it for the UTD to cost too much more??? Have you priced Kubota parts??? Every time i walk into my Kubota dealer i feel like i been raped!! Robert
Van(WA)
07-24-2003 06:42:56
Corkscrew; Why take a chance?? go with what the factory recomends. Your few dollars saved now will not look to good if you run into some repairs later, due to "cheap oil"
David L Burch
08-09-2003 10:56:10
 Re: Re: Any one have a problem with Tractor supply in reply to Van(WA), 07-24-2003 06:42:56
Looking for the owners manual for a 1947 Farmall model H (I think)..Need the wireing diagram. David....Thank You !
DoubleR
07-24-2003 15:33:25
Use it in my 2150 kubota. I brought it new 10yrs ago and have used it since I got it. I also have a loader on it and work it pretty hard. Never had a problem with the hydralics on it. Although I do use the good stuff in the engine. For what its worth??
Slowpoke
07-26-2003 14:29:52
 Re: Re: Re: Any one have a problem with Tractor su in reply to DoubleR, 07-24-2003 15:33:25
If the description says it's a replacement for Kubota UDT, I'd be concerned. If the description says "Meets Specification for Kubota UDT", then it SHOULD be the same as the Kubota fluid.
