Tractor Talk Discussion Forum
I need to load my tires...
Bill Oakes NY
07-27-2003 08:29:07
... want to use something other than calcium. What non-corrosive product gives the best weight for the dollar? Also need help figuring how much product to buy - can someone tell me how many gallons of fluid is needed for a 16.9 x 24 tire?
Thanks for helping!
Tom
07-29-2003 05:49:42
 Re: I need to load my tires... in reply to Bill Oakes NY, 07-27-2003 08:29:07
Around these parts, no one will even install the calcium any more. Everyone has switched to water and antifreeze. Ben using the water/antifreeze for years with no problems. Even had a flat on the rear and they were able to pump the remaining water/antifreeze out and re-use it by just adding some more antifreeze. Don't want any calcium - - ben there done that.
ted
07-27-2003 20:50:04
Calcium is best for weight and money. As long as it's over the rim there is little corrosion. With a tube you can fill it at any level up to just over the rim. If against Calcium, cast wheel weights may be your best option.
here, try this
07-27-2003 18:08:21
calcium gives the best weight per dollar. If you have good tubes it should be good forever.
Tractor Dan
07-27-2003 13:41:57
i use used antifreeze i dont have any problem with it at all
paul
07-27-2003 08:48:03
Rim-Guard or the beet pulp stuff.
Antifreeze is hazardous & too light, IMHO.
--->Paul
Big Jim
07-28-2003 10:01:40
 Re: Re: I need to load my tires... in reply to paul, 07-27-2003 08:48:03
Paul, Also if you do the math, gallon for gallon, antifreeze is much more expensive than calcium.
