Tractor Talk Discussion Forum
IH 100 hydraulics
bob s
07-29-2003 16:52:55
have a I. H. 100 question,are the hydraulics a open center system or a closed center system? any and all ideas much appreciated. tia
Gary-Miss
07-29-2003 18:36:48
 Re: IH 100 hydraulics in reply to bob s, 07-29-2003 16:52:55
closed center-Do you have a problem with yours? I have a little experience with them
bob s
07-30-2003 17:23:47
 Re: Re: IH 100 hydraulics in reply to Gary-Miss, 07-29-2003 18:36:48
gary
no trouble yet! am thinking of putting a hyd cyl on the front for a snow plow ,and was trying to decide what kind of valve to buy? any advice about spliceing into the hyd lines would be helpful
bob s
Gary-Miss
07-30-2003 18:34:28
 Re: Re: Re: IH 100 hydraulics in reply to bob s, 07-30-2003 17:23:47
The simplest method is to purchase a hydraulic line setup and open center spool valve for a fast hitch farmall. It will be a bolt on for your tractor and consists of the pipes running from the pump back to the touch control and the valve itself which bolts to the touch control. Hopefully, oyu can buy these used. If that fails you can cut into the small (pressure) line from the pump at any point and plumb an open center spool valve into it. These work really well. It will not affect your touch control operation, although you will need to use double acting cylinders since the touch control does not have that much storage capacity.
bob s
07-31-2003 17:15:29
 Re: Re: Re: Re: IH 100 hydraulics in reply to Gary-Miss, 07-30-2003 18:34:28
gary
understand cutting into pressure line and double acting cyl,would you need to cut into the big or return line also to get rid of the oil on one side of the cyl that is not pressurized? please explain to this hyd. novice
Gary-Miss
07-31-2003 20:36:42
 Re: Re: Re: Re: Re: IH 100 hydraulics in reply to bob s, 07-31-2003 17:15:29
You don't cut the big line. You just cut the little line (the pressure side). The spool valve has an inlet and outlet. Put you inlet side toward the pumpand connect the outlet side toward the touch control unit. If you are not using your remote ylinder, the pressure simply flows through the spool valve unimpeded. The other two opennings go to your cylinder(s)
bob s
08-04-2003 12:40:59
 Re: Re: Re: Re: Re: Re: IH 100 hydraulics in reply to Gary-Miss, 07-31-2003 20:36:42
thanks gary i will give this a try before snow flys this november
