Tractor Talk Discussion Forum
Ford 801 Diesel will not run
Bruce Cunningha
07-31-2003 19:36:03
Our 801 Diesel, starts easily and dies after 1-3 seconds, it will do this over and over again. I cleaned the air oil bath cleaner and air tube. Drained and flushed the fuel tank, and replaced the fuel filter and line between filter and pump. Is my injector pump bad and were do you send it for testing and service?
andyd
07-31-2003 21:52:38
 Re: Ford 801 Diesel will not run in reply to Bruce Cunningham, 07-31-2003 19:36:03
Check the kill lever on the injector pump, make sure its all the way on? the linkage can be binding? or the little strainer in the fuel inlet is stopped up you aint getting fuel?
