Tractor Talk Discussion Forum
1946 JD Brake Drum Removal
Charles
08-06-2003 10:56:25
How do you remove the brake drum from a 1946 JD Model B? I hear a rubbing noise coming from the left brake when the tractor is in motion, and would like to inspect brakes
Jim
08-06-2003 13:17:21
 Re: 1946 JD Brake Drum Removal in reply to Charles, 08-06-2003 10:56:25
Charles,
You need to remove the entire brake assembly from the tractor. After that you will see that on the gear end there is a cotter key and nut. Remove the cotter key and nut then the drum and shaft should slide off from over the shoes. Good Luck!
Jim
Charles
08-07-2003 13:44:58
 Re: Re: 1946 JD Brake Drum Removal in reply to Jim, 08-06-2003 13:17:21
Jim
Thanks for the information. Is there a gasket between the brake assembly and tractor? If so being 57 years old I would assume I need to order a replacement.
Thanks...Charles
