Tractor Talk Discussion Forum
580 b case
j endeavors
08-06-2003 21:07:13
I got an old 580b backhoe that had a bad ring gear and main drive shaft ( teeth torn out, etc) Rebuilt it and ran it. Now @ 6 months later I now have a torn up ring gear again. I was very careful not to abuse this machine and don't know what happened. Anyone have any Ideas ( or a ring gear for sale??) what may i have done wrong??
Thanks
george md
08-06-2003 22:29:04
 Re: 580 b case in reply to j endeavors, 08-06-2003 21:07:13
Did you set the pinion depth and the back lash
to spec ? Worn or broken thrust washers will
give you too much back lash .
george
Rod F.
08-06-2003 21:11:05
Does it have the correct starter and drive? Ring gear seated properly? Just a couple of thoughts.
Rod
