Tractor Talk Discussion Forum
Tractor pulling
don c
08-11-2003 11:46:05
Going to pull for the first time this weekend with a stock 1948 farmall H in the 4500# class ,could use some advice
Richard
08-12-2003 11:54:35
 Re: Tractor pulling in reply to don c, 08-11-2003 11:46:05
Start out with no less than 12 lbs in tires and go down from there. If you go below that starting out you will be very disappointed from lack of power.
Jason
08-12-2003 11:35:53
Try to get it as light as you can. Get that hitch up to the highest you are aloud to. Let a good bit of air out of tires. If its a hard track run about 7.5 to 8 pounds if its a soft one go down to about 5.5 to 6 pounds. I think it is great that you want to go out and try the old girl out,but when you go into a pull with a stock tractor you normally won't do to well. Its fun though, go ahead and give it a try. You never know it might surprise you.
Wendel
08-12-2003 09:49:47
First thing you need to know is the rules for the pull have hitch as high as allowed and as short depending on tire,wheel size run them 8-12 psi also depending on track.If you can its good to have about 200 lbs. to move to front or rear as needed when you get to the pull look at other tractors like yours ask questions most guy will give you pointers and or a little b.s. good luck and the best part have fun!!!
marlowe
08-11-2003 17:09:27
try to get in 4000 your going to run up against M=H 44 IHC M and oliver 88 and 77 your h is going to be out powerd
SHANNON
08-12-2003 00:34:14
 Re: Re: Tractor pulling in reply to marlowe, 08-11-2003 17:09:27
wheres that tractor pulling at? im going there at end of aug ... first time for me too... just gotta try it out and you ll figure something out.. but good luck! shannon
