Tractor Talk Discussion Forum
Delco 10SI Alternator
Rod (NH)
08-13-2003 14:48:17
Does anyone know if the 10SI can be easily changed in the field to move the location of the plug connection from, say 3:00 to the 12:00 or even the 9:00 locations by simply rotating the rear housing section without complete disassembly?
Bob
08-13-2003 17:17:42
 Re: Delco 10SI Alternator in reply to Rod (NH), 08-13-2003 14:48:17
Yes. Remove all four screws, and CAREFULLY pry the halves apart just enough to loosen them to allow rotation. The laminated stator, or middle section MUST rotate ALONG WITH the REAR section, and be free of the front (pulley end) as it turns. Pry sections apart only enough to free the front section from the middle section, AND NO MORE, or your brushes will drop off the sliprings, and be broken when the sections go back together.
Thanks Bob - Rod (NH)
08-13-2003 19:05:18
 Re: Re: Delco 10SI Alternator in reply to Bob, 08-13-2003 17:17:42
n/m
deadeye
08-14-2003 04:35:18
 Re: Re: Re: Delco 10SI Alternator in reply to Thanks Bob - Rod (NH), 08-13-2003 19:05:18
You can take the alt. clear apart also. Take a piece of stiff wire and load the brushes with the spring tension on it before assembly. Once you get the housings together in the position that you want, simply pull the load wire out of the hole from the outside.-----deadeye
