Tractor Talk Discussion Forum
Bad tractors
Wm.
08-16-2003 04:13:23
Based on information received here and elsewhere, I am potentially looking for the following models. Is there anything to look for / be aware of for these: Ford 8000 MF 285 IH 756, 856, 706 Case 830, 930, 970 White 2-70, 2-75, 2-85 Oliver 1750, 1755, 1800, 1850, 1855, 1865, 1900, 1465. I am really concerned with major problems, (understanding that prior use/care is a big factor), and am hoping to avoid what may be obvious to you who own/know these. Thanks very much.
720diesel
08-19-2003 12:21:08
 Re: Bad tractors in reply to Wm., 08-16-2003 04:13:23
wm,have you considered the john deere 4020? it is a great tractor! there is a lot of them still aroud working and being used as utility tractors.good luck finding a tractor!!
moonlite
08-16-2003 19:59:59
Is the Bularus considered a tractor?
NO
08-17-2003 05:36:14
 Re: Re: Bad tractors in reply to moonlite, 08-16-2003 19:59:59
Rufus Windrow
08-16-2003 14:28:59
Make sure you stay away from the Arbuckle Plow Jockey model F, especially those with the single rear wheel. Nothing but trouble with those air operated hydraulic units. I know from experience ... if you see one advertised, burn the newspaper it came from immediately and forget you ever saw the ad.
Larry from MD
08-16-2003 11:26:59
I am an oliver fan,but make sure to avoid the 1855.1955,1865,1465
Shane
08-17-2003 05:35:22
 Re: Re: Bad tractors in reply to Larry from MD, 08-16-2003 11:26:59
Add to the list- 2255.
ShepFL
08-16-2003 19:18:26
Ditto Larry's comments. He is dead on the money. I own one Oliver and have been looking for a deal on a bigger Oliver. Based on comments from Larry and others, their collective experience, and wonderful insight plus some of my own research I have settled on trying to locate a WFE DSL 1650.
Lots of wisdom shared on these pages, you are doing well to heed this. Regards
Jim
08-16-2003 07:19:56
What is wrong with the IH 706, 756, & 856 tractors? The time when they were built IH had some of the best workmanship.
Nebraska Cowman
08-16-2003 04:20:51
unless you have prior expierience and dealer support in your area, i'd stay away from white and oliver. The IH models will be the easyest to find parts for. ford 8ooo is a good tractor bu not as common.
