Tractor Talk Discussion Forum
how has the big blackout affected you?
tl rich
08-16-2003 05:36:19
We were not in the blackout area, I just wondered how others adjusted to the dark.
buickanddeere
08-17-2003 02:41:30
 Re: how has the big blackout affected you? in reply to tl rich, 08-16-2003 05:36:19
I was in the Bruce A nuclear power plants when all the class 3&4 lights all went off . Bruce B tripped the turbines, opened the steam release valves and went on poison prevent. We all looked at each other..... ..... Called the wife who was in the Pickering nuclear plant and she just seen the Shift Superintendent and a couple of 1st operators run down the main hallway which as also only lit with class 2 power. The stand by gas turbines where winding up,the steam turbines had tripped and steam release valves were open. Knew then the situation was huge. We had a couple of voltage spikes/dips knock our office computers off line at the Bruce at approx 3PM and 4 PM, trouble was in the works then. Darlington and Pickering lost all units for 36 to 40 hours due to Zeon poisoning because of the new stupid *ss procedures. Then afterwards it takes most of a day to start a unit from a extended shutdown. Used to trip turbines and even reactors on occasion and if the problem was known and corrected we would bring them back before the 20 window was gone. The bulk of Toronto had to wait for electrical power until after Pickering/Darlington could be restarted. The coal,gas and hydro electric plants managed to supply some essential loads with rotating blackouts once they decided the 500,000v and 230,000v grids could be re-energized. Western Ontario had better be grateful to Bruce Power, for the three out of four units they saved. We had power back on the grid by 7:00PM Thursday. I started my "pos" Coleman generator and it failed after two minutes from a grounded rotor before I even added load to it.
Trevor
08-17-2003 07:55:17
 Re: Re: how has the big blackout affected you? in reply to buickanddeere, 08-17-2003 02:41:30
buickanddeere,
Good to get some stright poop from you as to what was going on at the nukes.
I spent ALONG time a work at the motors waiting for the OK to turn on the power. Finally was able to turn on some critical loads on Friday morning at 8 am (I think) but we were told that if we went above out 6 MW limit they would shut us down again. We weren't allowed to increase our load until Sat morning.
How long was your house without power? My wife was manning the house and we didn't get anything till 1 PM on Saturday. Then went throught the rotating blackouts (2 hrs on - 2 hrs off) till Sat night.
Talk to you later.
Trevor
Dale
08-16-2003 19:38:50
Milked by generator Thursday night, unfortunately the generator blew just after we finished but the power came back on about 1 AM Friday and it's been on ever since. Mostly just been enjoying listening to Toronto radio and how much they're all complaining about not having AC for 12 hours. Power line maintenance has been so poor in rural areas here in Ontario that we're getting used to not having power for fairly long stretches.
Gene Davis(GA)
08-16-2003 19:26:01
Down here all we got from it was the newscasts, we had no problems here. Local utilities, Co-op and Ga.Power have been upgrading lines for about 5or 6 years. Some years ago I bought a generator, and a guy at work asked me why I wanted all the money tied up in that thing and my answer was, "call me when the lights go off and we'll discuss it then", Standby power is well worth the expense!!!
Gene Davis(GA)
08-16-2003 19:24:29
Down here all we got from it was the newscasts, no problems here. Local utilities, Co-op and Ga. Power have been upgrading lines for about 5or 6 years. Some years ago I bought a generator, and a guy at work asked me why I wanted all the money tied up in that thing and my answer was, "call me when the lights go off and we'll discuss ut then, Standby power is well worth the expense!!!!!
Richard Fazio
08-16-2003 16:23:53
I had to walk out of mid town manhattan over the 59th street bridge and out on the LIE a few miles till my son could pick me up. We were out till friday morning on Long Island.
Irv
08-16-2003 12:43:38
I got sent home from work.(GM) We aren't going back in till Mon. Cool - a nice weekend off.!!!!
Vern-MI
08-16-2003 12:42:36
32 hours without power or water in Plymouth Township, MI. Portable generator kept food from spoiling and ran sump pump. It was a little hunorous listing to the protable radio and how the politicians in each state said the problem did not originate there but in the neighboring state or province. Who cares where it started just figure out what happened so it can be prevented. Sure makes me realize how dependent we are on utilities.
KURT (mi)
08-16-2003 16:51:14
 Re: Re: how has the big blackout affected you? in reply to Vern-MI, 08-16-2003 12:42:36
Yep, politicians dont do anything but flap their jaws at the problem. And Detroit Edison has you by the %alls. I bought a generator 5 years ago and use it about twice a year now.
brett from mi
08-16-2003 11:35:06
we only lost power for up to 12 hours total so it wasnt to bad. we got it back and havent had a problem with it since. we had a little generator that worked for us. not to bad in the southeastern part of michigan.
gene b
08-16-2003 09:49:58
this site is for tractor talk
Les...fortunate
08-16-2003 09:28:29
I noticed a big decrease in the amount of spam that usually arrives at my computer.
Dave_Id
08-16-2003 07:12:54
I got nauseated listening to the ignorant politians pointed fingers at each other on the news channels
Davidj
08-16-2003 07:07:14
Here in Eastern Ontario we were lucky. Only out 3 hours or so in the country. The cities are still rotating blackouts as of this morning. We had a big ice storm in '98 that knocked us out here for anywhere from a few days to a few weeks so everyone and their dog has a generator in these parts.
