Tractor Talk Discussion Forum
Can't get PTO shaft off!!!!!!!!
COLBY TX
08-17-2003 07:50:52
I bought a 1973 ford 2000 3cyl diesil import last weekend and tried to get the bush hog off and can not disconnect the pto from the tractor. I pulled the shaft apart so I could get behind it and work. It is the kind with (I guess) a compression ring that I believe you slide forward and then just pull it off. I have never had this type before and did not want to get too crazy with it. I held it forward and tried to work it back and forth and could see play on the pto shaft, so I know the yoke is not froze up to the pto shaft. Any suggestions!!!!
Also, I posted a pic of the head lights this AM on this import, if you know where I can get new bulbs for them, let me know.
Thanks,
Colby
Tenaha, TX
Jailkeeper
08-17-2003 08:23:22
 Re: Can't get PTO shaft off!!!!!!!! in reply to COLBY TX, 08-17-2003 07:50:52
Try pulling the lock ring toward the rear of the shaft. All the ones I've ever dealt with always went to the rear. If that doesn't help, stick a prybar in the pto shaft so you can get some leverage to pry it off. Good luck.
DUH! Thanks Jailkeeper
08-17-2003 11:01:57
 Re: Re: Can't get PTO shaft off!!!!!!!! in reply to Jailkeeper, 08-17-2003 08:23:22
It would slide about 3/4" twards the tractor so I thought that was correct. It was stuck gouin backwards but it broke loose.
Jailkeeper
08-17-2003 11:36:58
 Re: Re: Re: Can't get PTO shaft off!!!!!!!! in reply to DUH! Thanks Jailkeeper, 08-17-2003 11:01:57
Glad ya got it. At least you didn't get the flame wrench ready!!!!
