Tractor Talk Discussion Forum
rear tires
Greg Miller
08-18-2003 09:32:47
at some time i will be considering replacing the rear tires on my tractor. does anyone have any suggestions or comments as to the type? 23 degree? standard field and road? any others? forget brand for a minute please. only interested in tread patterns right now.
thanks
greg
Adam B.
08-18-2003 22:38:45
 Re: rear tires in reply to Greg Miller, 08-18-2003 09:32:47
Without any more information, I'll have to assume you're looking for a general-purpose tire in a size common enough that you'll actually have a choice in what tread you can get. So I'll talk tread from my experience.
For general-purpose, you should be looking at R-1 category tires. Deeper tread doesn't always mean better traction. The tread depths/spacings are specifically designed for their applications, and if you go with R-2 mud tires for everyday dry or only slightly wet soils, you are likely to have increased tire wear and less traction than the R-1 tread. There's an in-between, the R-1W that fills the gap between R-1 and R-2 if you'll be using the tractor in both fairly wet and fairly dry conditions.
45 degree long bar: Often seen on antique tractors, they have good forward and lateral traction.
23 degree long bar: Modern tire design. Puts more power to the ground, and cleats seem to clean better in wet ground (compared to 45 degree). Seems to have less lateral traction than 45 degree, long/short, and short/short tread patterns.
Long/short bar: The idea behind this tread is staggering the leading points of the cleats to improve the biting surface, and to provide different lug angles on the same tire. Goodyear's Dyna-Torque tires are an example. We've used them with success. The wear was pretty even and they had good life. In the end, I'm not sure they worked better than long/long bar patterns. I recall some occassional vibration on the road when using this style tire tread.
Short/short: Sorry, but again going to Goodyear for an example. The DT-710 is a short/short bar tire. We put these on the tractors we make hay with the last time they needed new tires. Overall, I've liked them. Because of how the short bars overlap, they have about as good traction in reverse as forward. Quite a bonus when backing a mower-conditioner up in a hay field with dew on it. If there was any slope at all, the long/short and long/long tires we used before were much more prone to spinning in reverse. No question, the short/short tread has a much smoother ride on the road. The downside to all the wonderful news is that the tread life appears to be shorter with this pattern. From Goodyear, the latest in this style appears to be their Versatorque, which is a completely non-directional pattern. That means the tread will bite the same in forward and reverse. I suspect it'll have the same problems with tread wear.
You need to think about what you intend to use your tractor for and what kind of soil conditions you'll encounter. Your tire dealer should be able to help you choose the right tread (if you have a choice available). I'm not trying to push Goodyear, either. We've used Goodyear, Firestone, Armstrong, BF Goodrich, Kleber and Titan. I can't say we had problems with any specific brand, or that one brand was superior to the others.
Adam B.
08-18-2003 22:06:00
kyhayman
08-18-2003 18:12:53
I prefer 23 deg but wind up getting mostly long bar short bar.
jjw57
08-18-2003 17:57:03
IMHO I would only look at the long bar/long bar type of tires.Ihave a set of L/S which came on one tractor but when they are gone I do not want any more. 23's wear well but I have heard of side slipping on wet hillsides.
REDMAN
08-18-2003 13:10:29
23 degree seems to be pretty good,if i was going to buy a set and the tractor is used alot i would get the deep treads,if not used alot i'd go with a armstrong or allied.
paul
08-18-2003 12:44:22
Road use? Field use? Lawn mowing?
Size of tractor? Heavy pulling? Light loads?
Ag tires, R4s, turf tires?
More info!
--->Paul
earlschieb
08-18-2003 10:30:06
That would depend a lot on tire size, what tractor, and what are you going to do with it ? I just replaced an almost new pair of GoodYear Dyna Torque II tires with a new pair of Firestone Field and Road tires on my Farmall H, I went to the Firestones because I didn`t like the long bar, short bar on the GoodYear tires, and I am in the process of restoring the tractor and wanted new, new tires on it. So, I guess what that I am trying to say is, we need answers to what I asked you above, there is a lot of different ways to go without knowing what you are wanting to do.
