Tractor Talk Discussion Forum
JD 730 PTO noise
O. Staton
08-19-2003 19:15:00
When using my 730's PTO especialy if the shaft to the imp. is offset and some power is needed it has a bad clattering sound. Before I dig into a lot of work on it, I am open to coments.
kjm
08-20-2003 20:15:33
 Re: JD 730 PTO noise in reply to O. Staton, 08-19-2003 19:15:00
Ask, Clooney on the JD board,he will know.
RickB
08-20-2003 17:19:38
I know the PTO idler gear (behind the first reduction cover) on my 730 needs to be rebushed. I can hear it slapping around when using the PTO.
david B
08-19-2003 20:02:58
Probably normal..Old JD's have a lot of clatter when pto isn't straight. Make sure the u joint yokes are timed together on the implement.
O. Staton
08-20-2003 11:25:48
 Re: Re: JD 730 PTO noise in reply to david B, 08-19-2003 20:02:58
Thnnks, but this is not the usual shaft noise and is coming from inside the tractor-sounds bad.
