Tractor Talk Discussion Forum
Framall 340
Wes
08-20-2003 07:15:43
A local dealer is offering a IH Farmall 340 diesel with 2 point and 3 point hitch and three bottom plow for $4500. Are there any problems with this tractor? Is the price reasonable - the tractor appears to have been well taken care of. What inspection items should be on my checklist? Thanks.
Jerry
08-21-2003 21:14:01
 Re: Framall 340 in reply to Wes, 08-20-2003 07:15:43
Do the same things you would do with buying a car. Check the oil and hydrolics for moisture in the oil. Look for noticible leaks. Start it, listen to it for noises out of the ordinary. Run the 3 pt up and down, engage the PTO. Ask to drive it in the lot, so you can check brakes and steering. Make sure guages all work, as well as lights, etc. There is probably a few things I left out, but mostly, just use common sense.
Do you know what year it is?
Depending upon its condition, the price isn't bad.
