Tractor Talk Discussion Forum
Stubborn Brake Adjusting rod on IH 240
Jerry
08-21-2003 21:00:17
Does anyone have any suggestions how to get the Ball Nut off of the brake actuating rod on an IH 240-U I've Liquid Wrenched it, WD-40'd it, and even used a 1/2" drive Impact wrench at low setting, and nothing will move that SOB. I have even tried heat, though not a great amount, as I don't want to burn or melt the rubber boot. Any suggestions anyone may have would be helpful.
Nebraska Cowman
08-22-2003 18:32:03
 Re: Stubborn Brake Adjusting rod on IH 240 in reply to Jerry , 08-21-2003 21:00:17
I heat it up good and hot; try it, if it don't come then let it cool and use penetrating oil. You might cut the boot with your knife and take it off. The worst that can happen is you might have to buy some new parts. IH should still be able to get them.
Jerry
08-22-2003 19:58:42
 Re: Re: Stubborn Brake Adjusting rod on IH 240 in reply to Nebraska Cowman, 08-22-2003 18:32:03
Thanks Neb Cowman. I guess thats my next route. If I can get it off at the sacrifice of the rubber boot, I shouldn't complain. I have been letting penetrating oil(Liquid Wrench), seep into it all day. Every couple hours I tap it with a hammer, and dribble a little more on it. I'll try the impact wrench at a low setting tomorrow, and if that doesn't work, I'll turn the sucker bright red with the torch.
