Tractor Talk Discussion Forum
F20 rear tire assembly
Mark
08-27-2003 09:58:59
I patched a tire and pu in a tube but when I re-mounted it, I get a 'popping' sound as the tire rotates when I drive...It sounds the bead popping or something but I have no idea. I did remove the cast center and re-mount it; could I have screwed something up when I re-mounted the wheel? Any ideas would be appreciated. Thanks in advance, Mark
Nebraska Cowman
08-27-2003 17:11:07
 Re: F20 rear tire assembly in reply to Mark, 08-27-2003 09:58:59
sounds like the rim is loose on the wheel. that will make a popping sound.
mark
08-27-2003 20:17:21
 Re: Re: F20 rear tire assembly in reply to Nebraska Cowman, 08-27-2003 17:11:07
Thanks, I'll bet that is it! Mark
