Tractor Talk Discussion Forum
Farmall B clutch rod re-connection
David Snodgrass
08-30-2003 06:07:30
The clutch rod has come apart in the hollow cavity in the middle of the tractor
body. It appears to be a threaded sleeve that was holding it together. About 5/16"
pipe thread. Do I have to split the tractor to get it back together?
Thanks in advance for your help.
Gary-Miss
08-31-2003 18:32:22
 Re: Farmall B clutch rod re-connection in reply to David Snodgrass, 08-30-2003 06:07:30
You might as well split it rather than wrestling with it and then still have tosplit it. Hold the engine up with a hoist just as you would pull the engine. If you hook the chain at the rear only, it's likely to turn upside down on the narrow front end. The clutch housing end is not bad heavy.
gene b
08-31-2003 08:18:12
Sounds like you have amess as there is no coupling in the linkage someone has rigged a mess better split and fix it rite. There is no 5/16 pipe thread. You can e-mail me if you need more info.
