Tractor Talk Discussion Forum
Penetrating oil
endeavors
09-01-2003 21:39:02
What is the best penetrating oil and or the best way to loosen stuck nuts, bolts, levers, etc....
Just curious what others have used.
deadeye
09-03-2003 01:47:24
 Re: Penetrating oil in reply to endeavors, 09-01-2003 21:39:02
There are a few good ones around. PB works good as a rust breaker. Not a good lubricate. You have to be careful with it on some things. I got some of it on a Craftsman trouble light and it desolved the plastic. Fell to the floor and broke into a million pieces. It just crystalizes plastics. Marvel Mystry oil works good if you have a lot of time. WD-40 is terrible compared to most others unless it is just a quick fix and you don't have anything else. Most sprays with silicone in them are good for lubrication that last. Also sprays with the graphite which I use on garage door rollers are good lubricators. Lots of good ideas here. If all else fails, soak it in water. I have tried that on carburators and it works after 3 days. It froze it up and broke it loose after years of setting around.--deadeye
Oldfarmboy Jim
09-02-2003 22:58:12
I get the best results with PB Blaster. Next is Liquid Wrench. WD40 is about the same as 3in1 oil, not very good.
Steve450
09-02-2003 21:50:57
I work in a stone Quarry and one smell that you will never forget is PB Blaster mixed with rock dust!!! We use it on EVERYTHING. We buy it by the truckload and every once in a while a can makes it's way into my lunchbox:) I have never used Kroil, but I might order a few cans to try.
RayP(MI)
09-02-2003 18:35:24
Once I get things loosened up, my favorite for long term lubrication is "SUPER LUBE". It has teflon, and a heavier base which protects and prevents rust far longer than most other products, like WD-40, etc.
marlowe
09-02-2003 17:55:32
well you can all call me NUTS but i use fly spray [yes] fly spray comes in 1 gal.can from feed mill or fleet farm. just try it it's the best thing i have found
Nolan
09-03-2003 03:20:28
 Re: Re: Penetrating oil in reply to marlowe, 09-02-2003 17:55:32
That's different enough I'm going to have to try it. Kinda makes some sense though. Most fly sprays are an oil, and a light one at that.
George
09-02-2003 15:19:55
"The best penetrating oil is the one you used last before something loosened up!"
I have had real good luck with Gibbs, plus it can be used for all sorts of other things like starting fluid, moisture displacer, rust preventer, etc.
Scrub
09-02-2003 15:13:06
PB blaster is what I normaly use but I will buy "Free" when I can find it. I have only found it in one place and they quit carrying it. It is made by certified chemical and is mainly for industrial use.
Glen in TX
09-02-2003 13:22:46
I like the Kroil. They make it in aerosol called aerokroil and with silicone called silikroil and also a graphite penetrator in aerosol. Find it at kanolabs.com , not in stores. The best thing to use with any penetrating oil is PATIENCE.
Ben in KY
09-02-2003 12:15:07
I use PB Blaster and and as soon as it breaks loose I spray silicone on it to ease its removal. PB Blaster is good on rust but doesn't lube worth a darn.
Glenn-WV
09-02-2003 11:39:51
I also like PB Blaster and Kroil. Have also used Liquid Wrench with success, but it doesn't seem to penetrate as fast.
JD-Tractor
09-02-2003 09:56:12
Product called fluid film works better than PBblaster and then leaves protection on the fastener!!!
Trevor
09-02-2003 10:40:28
 Re: Re: Penetrating oil in reply to JD-Tractor, 09-02-2003 09:56:12
Interesting, I have never seen this product mentioned but it is what we use and my father swears by it.
Fluid Film gets my vote too.
Are you in Canada? Maybe it is a Canadian brand.
rustyfarmall
09-02-2003 07:06:14
Actually, I have had pretty good luck using a mixture of diesel fuel and brake fluid, if I need a bit more lubricating ability, just add a little motor oil to the mix.
Indydirtfarmer
09-02-2003 08:04:27
 Re: Re: Penetrating oil in reply to rustyfarmall, 09-02-2003 07:06:14
Brake fluid, diesel fuel, and automatic transmision fluid (Dextron if it makes any difference)
Chris-se-ILL
09-03-2003 09:42:56
 Re: Re: Re: Penetrating oil in reply to Indydirtfarmer, 09-02-2003 08:04:27
Just a note, Indy... That brakefluid will peel or discolor painted areas! Be careful where you use it!
Clint @ MD
09-02-2003 09:32:10
Indy- What ratio are you using for this mixture? I'd like to try it sometime.
Thanks.
sod
09-02-2003 07:03:01
ZEP45
good luck
sod
Nolan
09-02-2003 05:25:40
Liquid Wrench *with Teflon* is my favorite.
It's no better at breaking free then PB Blaster, Kroil, Break Free, or a number of other very good penetrating oils. Where it beats them hands down is once I've broken the fastener free.
Many times with things like Kroil or PB you end up jammed because of the rust particles in the threads. The Liquid Wrench *with Teflon* lubricates and seems to float the rust well. Rarely do I end up with damaged threads, or have to use force, once the fastener is broken free.
My favorite tool for breaking free a rusty or frozen fastener is a hammer. A series of sharp raps will tend to break up the corrosion or rust and release the fastener. This is especially good on steel bolts or studs in an aluminum housing.
Robert Cornell
09-02-2003 05:08:12
PB Blaster is great, but I have had even better luck with an industrial product called Kroil made by Kano Labs.....I am not sure you can buy it unless you have an industrial account??? At least it used to be that way....
mike
09-02-2003 06:30:33
 Re: Re: Penetrating oil in reply to Robert Cornell, 09-02-2003 05:08:12
you are right, it is from Kano and I have had very good luck with it. On the can it says to order direct from Kano at 615-833-4101. if they have a distributor nearby they should tell you.
Mike (WA)
09-02-2003 08:15:28
 Re: Re: Re: Penetrating oil in reply to mike, 09-02-2003 06:30:33
My understanding is that they don't have distributors or retail sales- its all mail order, phone or website- kanolaboratories.com
MarkB
09-02-2003 18:27:56
 Re: Re: Re: Re: Penetrating oil in reply to Mike (WA), 09-02-2003 08:15:28
Kroil can be found at retail outlets. I bought mine at Cabela's sporting goods.
Glen in TX
09-02-2003 09:25:57
I have had great luck with Kroil. You can only get direct from Kano Labratories as mentioned earlier. You can buy 1 or 2 cans to try or cases or by bulk in pour can. Been buying the aerosol cans by the case for years and can never find mine because they seem to grow legs so I had to lock the shop.
Miss Grundy
09-02-2003 09:45:58
 Re: Re: Re: Re: Re: Penetrating oil in reply to Glen in TX, 09-02-2003 09:25:57
I betchu did not have them lined up at the door trying to escape. Possibly they were waiting for a ride
Alberta Mike
09-02-2003 05:05:15
PB Blaster was being sold up in these parts a few years ago. Someone was bringing it in then some salesmen were selling it on their own to some parts stores etc. But it never was really imported legally so I've been told. Something to do with labelling problems (no French if you can believe that). I still don't think it's available up here, some guy's were looking into bringing it in last thing I heard. A product called "Nuts Off" is supposed to be pretty good. I've used a line called "Moov-It" which also worked well.
REDS
09-02-2003 04:45:10
PB Blaster is great stuff. Try it, you will like it!!
F14
09-02-2003 03:44:14
Another vote for PB Blaster here.
I've also heard very good things about Kroil, but haven't found any to try it yet.
Eric Hosette
09-01-2003 22:03:24
I have always used PB Blaster Penetrating Oil. I have had great success with that. It broke loose two pistons in a stuck engine and numerous nuts, bolts, etc. I have also hear great stories about Gibbs Penetrant. I have never used it myself, but I heard it works wonders.
Stan TN
09-01-2003 23:54:53
 Re: Re: Penetrating oil in reply to Eric Hosette, 09-01-2003 22:03:24
Second the motion, it actually disolves rust.
