Tractor Talk Discussion Forum
1510 ford tractor
sonny
09-04-2003 16:33:03
when i lift the implement off the ground it starts to bounce up and down can someone help me i have already changed the filter and fluid
paul
09-04-2003 18:52:52
 Re: 1510 ford tractor in reply to sonny, 09-04-2003 16:33:03
Does it bounce, or gently bob up & down? how much?
How heavy is the implement you are lifiting? Does it do this with lighter items, a real heavy one, or?
--->Paul
Paul in OH
09-04-2003 17:53:50
I don't know the cause of that but since you mention filter and fluid you should know there is an inlet screen as well. It's on one side or the other near the back of the tractor. It's a tube coming out with a round base and three or four bolts holding it on. You first verify location side with a NH parts dealer and get a new gasket. The metal screen gets washed in a solvent but don't damage it. I think the cost is $80. Good luck.
