Tractor Talk Discussion Forum
farmall H carburetor
mark comer
09-04-2003 17:09:34
HELP !!!!! ! I'm Frusturated with my carburetor.
I have a farmall H 1949 and need info on the carburetor. What should the float be adjusted at? About all the jet screws, how many turns should they be in or out???
any help would be appreciated.
Sincerly,
Mark..... owner of a piece of junk for a carburetor.
TWC
09-06-2003 20:16:50
 Re: farmall H carburetor in reply to mark comer, 09-04-2003 17:09:34
HAY MARK, I HAVE A 49 H MYSELF. JUST PUT A KIT IN THE CARB AND THE SPECS. ON THE PRIMARY ADJ. WERE 1-SET THROTTLE STOP SCREW TO 1-1/2 TURNS OPEN..2. SET FUEL ADJUSTING NEEDLE THREE TURNS OFF SEAT..3. SET IDLE ADJUSTING NEEDLE ONE TURN OFF SEAT. HOPE THIS HELPS, MY PROBLEM IS WHEN YOU TURN ON GAS. THE GAS POURS OUT OF THE CARB.REPLACED FLOAT, PUT IN KIT.THIS MADE IT WORSE?GO FIGURE.IF ANYBODY AT ALL COULD SHED SOME LIGHT ON THIS SUBJECT,PLEASE DO....THANKS....,
mark comer
09-05-2003 04:42:11
Steve, my e-mail is mcomer@erols.com about the carb spec.
Jailkeeper
09-04-2003 20:23:18
Mark, if you send me your email address, I can fix you up with the specs. on your carb. I have scanned the pages from my servicemans guide and will email it to you. They are in Adobe PDF format.
Steve
