Tractor Talk Discussion Forum
International 606 info
R. Brow
09-04-2003 17:17:37
We have a 606 that we have been using for 3 years now planting wildlife crops. Been having problems with the pto slipping( even after adjusting) and the hydrolics seem to get sluggish after 2-3 hours of running. Does this system take a special hydro oil?
I believe we are just using tractor hydralic fluid presently.
Thanks,
R.Brow
Jay
09-04-2003 18:19:01
 Re: International 606 info in reply to R. Brow, 09-04-2003 17:17:37
Per my Chek-Chart book:
HTF - which basically means Hy-Tran, Mobil 424 Fluid, Chevron 1000 Fluid, Exxon Hydro 560, etc. (These are the ones I'm familiar with and all quality products)
Per book: To drain, remove 3 plugs at bottom and 1 at top right. Models without power take-off and torque amplifier have 2 plugs at bottom and 1 at top right. When refilling (52 quarts by the book), leave filler plug out, then move position control and auxilliary valve control levers back and forth 10 to 12 times and return position and auxilliary valve levers to forward position. Actuate auxilliary valve control levers to retract remote cylinders. With power steering turn wheel to both extremes and return to center. Stop engin and add additional fluid as required and install filler plug. Drain and refill every 1000 hours or yearly.
R. Brow
09-04-2003 19:34:04
 Re: Re: International 606 info in reply to Jay, 09-04-2003 18:19:01
Thanks guys, you've been alot of help!
We are heading to the deer camp tommorow, I'll pick up some new hyd. filter and fluid and do the change. Very informative site for a part time farmer like myself, enjoyed reading the other posts about the 606. Have a great year!! Roger, Central Mich.
Red Dave
09-04-2003 17:41:49
It should use Case/IH Hytran hydraulic oil. Some of the guys on the Farmall/IH board can probably give you some more detailed help.
