Tractor Talk Discussion Forum
Tire Paint
Kiotigene
09-09-2003 17:21:17
I have seen an ad for tire paint that fills
the weather-cracks in an old tractor tire. I
realize this isn't a "fix" for a tire, but makes it "look" better. Any help here?
Thanks Gene
David Krowel
04-22-2004 09:17:42
 Re: Tire Paint in reply to Kiotigene, 09-09-2003 17:21:17
Where can I fine it
gene b
09-10-2003 04:29:01
The stuff i use i get from MILLER TIRE wont fill large cracks but sure makes tire look good. I scrub with soap and water then use two coats.
Paul in OH
09-09-2003 17:32:28
I've had poor results with these. Best bet is to get black silicone--the kind used to stick rubber auto gaskets to the doors. This will fill in the big cracks and stick surprisingly well. Then rub on some tire black with a rag on a clean tire and it looks pretty good. The best tire black -but I haven't seen it in a year or two--was Kubota brand from a Kubota dealer.
deadeye
09-10-2003 05:03:19
 Re: Re: Tire Paint in reply to Paul in OH, 09-09-2003 17:32:28
Here's what I do. I go to Wal-mart and buy shoe goo. Fill the cracks with that first, rubbing it on with your finger and let dry for a couple of days. Then use the tire black that Miller's sell. It is about the best I have seen. It will not wash off with water and does not create a shiney surface. Gives it the new tire look. I even used it on the steering wheel as it does not rub off.----deadeye
