Tractor Talk Discussion Forum
d-14 or d-17 allis-chalmers
roger
09-10-2003 20:00:46
How do you tell a difference. I also need brake parts and rods that move them
Aaron
09-11-2003 06:31:44
 Re: d-14 or d-17 allis-chalmers in reply to roger, 09-10-2003 20:00:46
As mentioned, check serial number. Also, a d-14 has 26" rear rubber and a d-17 has 28" The d-17 is larger both in overall size and hp. (55 hp) The d-14 is comparable in size to a WD allis both in physical size and hp. (35 hp)
John (C-IL)
09-11-2003 04:51:03
Check the serial number which is stamped on the flange of the torque tube, left side where the engine and the torque tube meet. D-17XXXX or D-14xxx. You can also check the engine serial which is also on the left side of the engine near the rear of the engine.
RJ-AZ
09-10-2003 20:51:31
The D-17 is coniderably larger than the D-14. Remember there is also a D-15 in the litter. The D-14 is maybe a 35 HP tractor and the D-17 around 75HP (I am not sure of these figures) but it's noticable.
JMS/MN
09-11-2003 07:28:41
 Re: Re: d-14 or d-17 allis-chalmers in reply to RJ-AZ, 09-10-2003 20:51:31
D17 is about 53 pto hp. D19 is about 63 pto hp.
