Tractor Talk Discussion Forum
Proper rain cap postion
PH
06-18-2007 17:10:37
which way is the best way? Backwards to stop tree branches from ripping the muffler off. Forward to blow the exhaust away. or I've seen some sideways.
Rich Va
06-19-2007 04:32:33
 Re: Proper rain cap postion in reply to PH, 06-18-2007 17:10:37
Most new tractors now have the curved end on the muffler to keep rain out. I would rather have the curved end muffler over a rattling rain cap. Anyway you choose is acceptable.
Ryne
06-18-2007 18:03:56
i usually set mine so the exhaust can flow out towards the back as the machine travels or to the side works also
Gene Davis (Ga.)
06-18-2007 17:32:47
If you haul a tractor or equipment with a turbo, you need the wind to blow the cap closed so the turbo won't windnmill the dry bearings when the oil pump is not pumping oil to the turbo bushings. Turbos are expensive when they run dry!!
Allan In NE
06-18-2007 17:19:39
They came new from the factory with the open side forward.
Allan
Donnie Baker
06-18-2007 17:14:11
You are kidding ain't you? What ever trips your trigger man there is no wrong way, I gotta go
john cub owner
06-18-2007 20:02:57
 Re: Proper rain cap postion in reply to Donnie Baker, 06-18-2007 17:14:11
If you haul the tractor it needs to be positioned so the air flow pushes it shut. that way if you get caught in a rain it won't act as a funnel to shove rain down the stack.
4010guy
06-18-2007 21:16:50
 Re: Proper rain cap postion in reply to john cub owner, 06-18-2007 20:02:57
I point mine the same way i hang my toilet paper!
