Tractor Talk Discussion Forum
Will a 9.5 tire fit a 10 rim
Massey nut
09-12-2003 06:25:07
I am restoring a combine, and the 11.2" x 24" tires are shot. I found some 9.5" x 24" tires really cheap. I think I have a 10" rim because the 11.2" tires that are shot say to use on a 10" rim. Can I use the 9.5" tires do you think?
Sid
09-12-2003 21:07:49
 Re: Will a 9.5 tire fit a 10 rim in reply to Massey nut, 09-12-2003 06:25:07
My tire man tells me not to use a tire that is narrower than the rim but it is OK to use a tire wider than the rim.
Aaron
09-12-2003 07:58:58
I have used tires that are one size smaller or larger on rims and have had no trouble. If you are going to use the machine, I'd go for it. If it is to restore, well you may want to stay original.
buck
09-12-2003 07:17:25
may not have that nice baloon look but should work fine. I would check the outside diameter as compared to the 11.2 tire. A tire supplier should be able to give the comparison
