Tractor Talk Discussion Forum
'41 JDB --no oil pressure
Ol' Farmer
09-14-2003 05:13:15
Had the oil pump and filter cannister worked on and have looked over the crankcase (internal)area for internal leaks but still get no pressure. Any ideas?? Has anyone had a similar experience and was able to fix the pressure problem? Thanks in advance.
Jerry (KS)
09-14-2003 19:43:14
 Re: '41 JDB --no oil pressure in reply to Ol' Farmer, 09-14-2003 05:13:15
I had almost no oil pressure on a 1940 JD B. I found someone had screwed the oil filter stud in far enough to raise the oil pressure relief leaf spring..... ...thus no oil pressure. Another possiable is the oil pump drive shaft is not turning because the coupling is worn out.
