Tractor Talk Discussion Forum
Farmall M carb indentification
Mik
09-15-2003 11:36:47
I am trying to identify the make/model of the carb on my M to order a rebuild kit.
The only # i can see on the carb is a raised numbering in the casting on the upper half of the carb...8557D.
is this the # i need to identify the carb make? or is there supposed to be another # somewhere?
thanks
Jim
09-16-2003 06:55:31
 Re: Farmall M carb indentification in reply to Mik, 09-15-2003 11:36:47
The Carburetor on your M was made by IH. There are 2 kits for the carburetor. The difference is the top of the carburetor and to tell the difference you will need the casting number to get the correct throttle shaft in the kit .
Bob M
09-15-2003 12:36:49
The carb part number should be stamped on a small brass disk riveted to the throttle body (upper) carb casting. The tag is often encrusted with dirt and varnish - may take some scraping to uncover it.
Punch below for an example (this one happens to be from a Marvel-Schebler carb on an MM tractor, but the Farmall tag is similar....)
