Tractor Talk Discussion Forum
Farmall Super A Engine
Lee
09-16-2003 07:30:50
I have a 1953 Farmall Super A and am told by the IH dealer that there were two sizes of engines. How do I identify what engine I have in order to get parts such as gaskets, etc? The tractors serial number is 345728J and the model number is FAA. I would appreciate any help I can get on this.
Richard Hill
03-14-2004 08:36:57
 Re: Farmall Super A Engine in reply to Lee, 09-16-2003 07:30:50
Could someone tell me where the transmission check plug is located on a 1953 farmall super A AND ALSO HOW MUCH OIL GOES IN THE BULL GEAR PAN???
Thanks,
Richard Hill
TURBO
09-16-2003 14:34:36
Yes you could have a C113 or a C123. The bore diameter is what determins the cu in. You can rebuild it to the 123 size no problem. Do you have water pump on this unit? Also you need to measure the liner o-ring seal diameter of block to get right parts. Should measure 3.311 or 3.437 in diameter. Simple engine if you need help let me know. Good luck.
Lee
09-16-2003 14:59:12
 Re: Re: Farmall Super A Engine in reply to TURBO, 09-16-2003 14:34:36
To Turbo:
The engine has no water pump. This is why I am trying to identify the engine. It pushes anti freeze out the radiator overflow after running 15-30 minutes at lower rpm. I think it needs a head gasket.
turbo
09-17-2003 16:48:31
 Re: Re: Re: Farmall Super A Engine in reply to Lee, 09-16-2003 14:59:12
Probably is a head gasket problem. Will only get worse. Be sure to get the proper head gasket. Without water pump the water port holes are larger for more coolant flow.
evielboweviel
09-17-2003 03:59:29
let it find its own level, then if it keeps going down worry about it. if head gasket is bad you will see bubbles in antifreeze as tractor is running or have antifreeze in oil.
good engines will spit out some water if filled full when cold and then run hard
Ben in KY
09-16-2003 19:05:33
Lee,
did you fill the radiator all the way full. I don't think you are supposed to fill it full. Someone else on here will know more than I about it though.
K-Mo
09-16-2003 12:46:48
The early Super A has a C-113 (113 cubic inch) engine. The later, S/N 310300 and up, used a C-123 engine. However not all C-123 engines are identical. They were used on Super A, Super C, 100, 200, 130, 140, 230, 240. You should use the casting number for parts identification. On my F-140, the casting number (XXXXX RX) is behind the oil filter.
K-Mo
Lee
09-16-2003 14:59:55
 Re: Re: Farmall Super A Engine in reply to K-Mo, 09-16-2003 12:46:48
To K-Mo,
Thanks for the help.
