Tractor Talk Discussion Forum
tire valves for calcium chloride
John
09-16-2003 18:13:06
I have a case VAC that has calcium chloride in the tires. every few years i have to replace the valves because they get eaten out. are there special valves that aren't affected by the Calcium chloride?
Roger
09-17-2003 18:06:42
 Re: tire valves for calcium chloride in reply to John, 09-16-2003 18:13:06
Consider tossing the Calcium and going to alcohol.
It won't eat up your rims. The local tire shop has
used alcohol for several years.
Mike
09-17-2003 04:08:47
Ihave worked for Good Year Ag tire store for the past 20+ years and I have never heard of a valve just for cal. chlr. They are all the same.
Rod F.
09-17-2003 17:28:29
 Re: Re: tire valves for calcium chloride in reply to Mike, 09-17-2003 04:08:47
That's what I thought too. Never heard of a special valve for CaCl.
Ray,IN
09-17-2003 22:26:33
 Re: Re: Re: tire valves for calcium chloride in reply to Rod F., 09-17-2003 17:28:29
Sorry about that guys, SST must be exclusive to Indiana I guess. The Goodyear farm tire store here doesn't have a clue either, the privatly owned tire store I patronize has them. I took a nearly new truck tire to them with a 1/2" bolt in the tread; they installed a combination boot and plug that sealed the hole and restrengthened the tire. I phoned several tire stores and none knew of the boot/plug repair(can't recall the name they used).
Ray,IN
09-16-2003 20:01:32
Yes, SST. Ask a farm tire shop.
