Tractor Talk Discussion Forum
39 John Deere Model aA
Dave N
09-17-2003 19:08:37
I thought i was sold a 39 john deere model a , now it turns out that it may be a 41 or later. it has a 3 speed tranny with high, low range with a shroud over the shifter. Any sure signs that it is not a 39. I was told 3 speeds came out in 41, is this true. Help
Marshall
09-18-2003 07:20:50
 Re: 39 John Deere Model aA in reply to Dave N, 09-17-2003 19:08:37
Dave,
Look on the right side of your tractor right in front of the belt pulley, you will see a number that tells the day and the year the tractor was made. It will read up & down. This is not the serial now; only the day and the year built. I also have an "A" without the tag also.
Marshall
Leroy
09-18-2003 05:34:01
Up thru 1940 they only came with a four speed and that was a 2 speed with high and low range, after market companies made a road gearadd on transmission that mounted on the left side of the transmission case, plainly visable, this would also be avaible for the 41-46 tractors that orignaly came out on steel and with the 4 speed transmission, the four speed did not have the cast shifter quadrent on, only the 6 speed and that continued on after the change from the angle iron frame to the pressed steel frame that came out as a 47 model, 47 and up only came with a starter, 41-46 most likely came with a starter if a 6 speed transmission, if 4 speed then most likely no starter, 39-40 could be gotten from factory with starter on 4 speed but verry rare, open radiator 34-38 you could get an add on starter, does it have an electrical system on it and if it does where is the battery, in hood or under seat? If you go to John Deere and get a parts manual for a styled A that will give you the information to date by looking for any changes made over the years. I have done that for one that I had and it was a late 51 or early 52 acording to the parts book, I just dated a B last spring for a friend the same way, any more questions email me.
dw
09-18-2003 07:55:33
 Re: Re: 39 John Deere Model aA in reply to Leroy, 09-18-2003 05:34:01
Dad bought a new 1941 B, on steel. It did not have fifth and sixth gears but had a shifter quadrant with the slot for them. After having rubber tires installed, he had the gears installed for fifth and sixth. If the 1941 A, equiped with steel, didn't have the same qaudrant as the rubber tired A, it was different than the B.
I Iike Case
09-18-2003 03:34:26
Thanks for the follow up but the serial tag is missing. Have any other clues for me?
Dave N
09-18-2003 03:32:22
Thanks for the followup but the serial tag is missing.
I Like Case
09-17-2003 20:33:02
Year Starting Serial Number 1939 477000 1940 488852 1941 500849
This information is located on the left side of this page. There is some very good info there. Have a look.
