Tractor Talk Discussion Forum
loader cylinder construction
RogeR
09-18-2003 19:17:09
I have a loader bucket cylinder that's leaking down. I took it apart and removed the packing and the seal and thought I would remember the proper orientation come time to replace them. Well, too much time elapsed for my failing memory and now I need help. These are "V" or "chevron" shaped packing rings. There are some on the end of the rod and some within the packing gland. So, which way does the cup face? Do both sets face the same direction? And the oil seal at the other end of the rod, which way does its' cup and spring face? I imagine there must be a general rule about these things, like the the way house insulation faces- backing paper toward the heated side of the house...
Thanks in advance.
Roger
marlowe
09-18-2003 19:35:58
 Re: loader cylinder construction in reply to RogeR, 09-18-2003 19:17:09
all seals go cup side to preasure side in all the rams i have resealed and if its a two way ram the same goes
RogeR
09-19-2003 06:09:37
 Re: Re: loader cylinder construction in reply to marlowe, 09-18-2003 19:35:58
marlowe;
Thanks for the reply. Cup to pressure. Makes sense. What about the oil seal, which is external to the packing gland, which direction does it face?
Thanks again.
Roger
marlowe
09-19-2003 19:13:15
 Re: Re: Re: loader cylinder construction in reply to RogeR, 09-19-2003 06:09:37
the out side seal is just a dirt wipper on most rams and most face out
