Tractor Talk Discussion Forum
John Deere transmissions?
Danny
09-19-2003 18:51:35
In simple terms what does a power shift transmission and synchro transmission have that is different from just a regular transmission or how do they work differently than just a normal clutch and shift transmission? Thanks.
JMS/MN
09-19-2003 22:35:51
 Re: John Deere transmissions? in reply to Danny, 09-19-2003 18:51:35
The JD Powershift is like an automatic transmission in that you do not NEED to use the clutch- they call it an inching pedal- to shift from one speed to another. With the synchro tranny, you have about 4 stations-= need to use the clutch to shift from one station to another. Each station has a couple of forward gears and some have one or two reverses. Within each station, the gears are synchronized, you use the clutch but do not need to come to a complete stop- they can shift on the fly. Powershift delivers less power to the drawbar, but is offset with the convenience of popping from one gear to another. Powershift lasts longer but costs more to repair. Since 1973 I've had four Powershifts, rebuilt one. Two have over 8000 hrs, one has over 10000 hrs, the one that was rebuilt was a plantation tractor with ? hrs. Meter showed 5000, mechanic said maybe 3x that.
JMS/MN
09-19-2003 22:32:47
RJ-AZ
09-19-2003 19:38:12
The power shift is basicaly an automatic trans without a torque convertor. The clutch is actualy a dump valve. There is a torque damper on the flywheel though. It is like a clutch with no release forks although JD did have a release mechanism on some early model 3020's.The PTO is part of this package also and is engaged hydraulicly.
The early synchro range is a pure gear transmission with a dry type clutch. The PTO is incorporated into the main clutch setup but is controlled by a seperate lever and not by a two stage pedal. The slot machine shifter really controls a 4 speed main with a 2 speed. This gives you 8 forward and 2 reverse speeds.
