Tractor Talk Discussion Forum
Standard axle Kingpins HELP!
Kelvin
09-19-2003 18:58:16
Its a MM ZAS and the old kingpins have cut through the bushing and into the knuckle. One side about 1/16" the other side a little less. No other parts South of the Mason/Dixon and East of the Mississippi, as far as I know. What are my options? Surely some of you guys have encountered this. What did you do?
georger md
09-19-2003 22:52:56
 Re: Standard axle Kingpins HELP! in reply to Kelvin, 09-19-2003 18:58:16
Kelvin,
Are you near the mason/ dixon line ?
I have repaired them before .
george
Kelvin
09-20-2003 05:28:06
 Re: Re: Standard axle Kingpins HELP! in reply to georger md, 09-19-2003 22:52:56
Actually, I'm in NC. Thanks for replying.
Kelvin
george md
09-19-2003 22:55:44
never could type
george
buck
09-19-2003 19:38:26
My first stop would be a good machine shop because the tools required to do the repair are quite expensive unless you have or have access to align reamers capable of doing this job. The object is to cut out utill you have a good surface and then replace the bushings with oversize or possibly even a larger kingpin.A front end shop that deals in larger trucks may be a good source of the repair and or parts. Do notlimit your search for parts to just your tractor but any kingpin set that will do the job. Nappa may be able to help if you have good dimensions.
