Tractor Talk Discussion Forum
John Deere 2130 - Over heating problem
Rob
09-22-2003 01:57:25
Hi There
I have an old JD 2130 which is overheating constantly. the water pump has been replaced and today I repaced the thermostat and still it boils over. Can anyone help? I have flushed the radiator and engine, maybe I have a faulty water pump. Should I see the water flowing fast when I open the radiator cap?
Help !!!
Cheers Rob
Tom
09-22-2003 06:07:14
 Re: John Deere 2130 - Over heating problem in reply to Rob, 09-22-2003 01:57:25
In my experience, replace thermostat, replace upper hose, replace lower hose, pressure test radiator cap, replace fan belts. If heating continues, see if water is circulating properly. Next take radiator off to radiator shop. Have boil-out or rod-out, depending on condition. Have shop clean external fins and straighten fins. Use 50/50 mix. DO NOT use any stop leak products.
