Tractor Talk Discussion Forum
6.00-16 tire
Hoosierbuddy
09-23-2003 17:53:17
I'm looking for a replacement for a plow tire ,does anyone know what size used car or truck tire will fit on my 6.00-16 rim?
Like a 155 R16 or something like that??
Or should I bite the bullet and spend 50 bucks or so on an Implement tire and tube!!
Thanks,
HB
JW
09-25-2003 18:36:13
 Re: 6.00-16 tire in reply to Hoosierbuddy, 09-23-2003 17:53:17
Depending on how the wheel is mounted onto the plow (4-bolt, 5-bolt, or single lock nut), you might consider checking on an automotive salvage for replacement rims for more common tires. The 6.00-16 tires (4-bolt) I have are old and were filled with foam. When they wear out I have some 8-bolt wheels that will hold worn out tires from my pick-up.
Ray
09-24-2003 16:56:25
An R16 tire like off a 3/4 ton truck will
work.We use them all the time for front tractor
tires,there 10 ply,implement tires are only 6
or 8 ply and don't last.Don't know were your at,but I've got a couple extra in the barn.
K-Mo
09-24-2003 05:49:56
If you have a mechanical trip plow, consider is using a tire with good traction on the trip side. I remember sometimes seeing plows with tire chains on the trip wheel to prevent slippage during lift.
K-Mo
Les...fortunate
09-24-2003 04:51:54
Hey Hoosierbuddy, I found a brand new looking pair of 11.00x16 tractor tires for sale in front of a house. I have no use for them but I bet they could be picked up for a song. Interested?
HB
09-24-2003 20:04:59
 Re: Re: 6.00-16 tire in reply to Les...fortunate, 09-24-2003 04:51:54
Too Big,But thanks Les!
David from Kansas
09-24-2003 10:17:50
Les, Are they threee or four rib? We go through lots of those 11:00-16 on the front of your baler tractors. Where are you located?
David
Les...fortunate
09-24-2003 20:03:34
 Re: Re: Re: 6.00-16 tire in reply to David from Kansas, 09-24-2003 10:17:50
They are three rib and I'm located in New Hampshire. The tires are in Gilmanton, NH. Long way from Kansas.
gene b
09-24-2003 04:36:10
Any reasonable size will work just remember you will have to reset the levers to level the plow when its tripped too large a tire could make leveling hard Bought a 3-12 once land wheel was a foot taller than furrow tire. what a mess
John in SD
09-23-2003 19:31:40
21585R-16 should work. 24575R-16 should fit the rim but could be too wide if you have any clearance problems. HTH
Hoosierbuddy
09-23-2003 21:12:09
 Re: Re: 6.00-16 tire in reply to John in SD, 09-23-2003 19:31:40
Thanks!!
