Tractor Talk Discussion Forum
IH 140
Steve
10-04-2003 20:01:12
I have a dumb question, and yes there are some!
I am not new to tractors or farming i am a Rancher now. But I just bought a 1975 International 140 and am almost finished with the restoration. But I have this dumb question that keeps nagging me but i know its dumb so i avoid asking, however i have no choice but to bite the bullet and ask. On the right side up front the distributor is mounted on a cast iron component in front of the distributor and this component is a small tank with a cap on it is this where the engine oil fill is or is it something else? there are two lines that run from this proximity to the hyd. tank. What is this small tank for ? am i right is it where the crankcase oil is added, Is it also a resivoir ? if so how do i know how much oil to add ? man i feel dumber than a box of rocks. any help would be most appreciated.
Gary Thomas
08-24-2005 10:48:06
 Re: IH 140 in reply to Steve, 10-04-2003 20:01:12
I am also in the processw of restorint an IH 140 and am in need of the international emlem on the right side which is metal?
Does anyone know where this can be found use or new?
Thanks
MD Wa.
10-04-2003 20:58:38
Steve. That is the hyd. pump in front the dist. The lines run back to the small tank. (hyd.) You use Hy-Trans in the hyd. system. If you do not have an owners mamual you can order one from Binder Books. Have fun & be safe. Morgan
Steve
10-04-2003 21:13:05
 Re: Re: IH 140 in reply to MD Wa., 10-04-2003 20:58:38
Thanks morgan,
so is that he reservoir for the hyd.? and my local IH dealer said to put 30w in it cause of seals blowing and contaminating the engine oil ?
TDK
10-05-2003 13:28:59
 Re: Re: Re: IH 140 in reply to Steve, 10-04-2003 21:13:05
The cap is for adding engine oil. Hyd. pump is mounted underneath distributer. Hyd. resivoir is underneath gas tank.
Steve
10-05-2003 19:55:31
 Re: Re: Re: Re: IH 140 in reply to TDK, 10-05-2003 13:28:59
ok , so i dont have to use the cap on top of the valve cover to add the engine oil ?
Thanks Guys for all the help I appreciate it
