Tractor Talk Discussion Forum
cub cadet 1250 hydro
david
10-05-2003 13:08:24
I have an older cub 1250 hydro. The other day it would not go in to gear( except high as fast as it will go) So I looked under the seat and along the linkage from the clutch/brake pedal back to the top of the hydropump / tranny. If you are sitting on the tractor it is on the left side. a rod that holds the linkage from the tran to the clutch /shifter exced. goes to the top of the pump. The pump has a rod and on the left side it has a part that is welded to the rod going through the pump. It must of had some sort of spring attachment but has broke of. Where can I get one and can I pull that rod out if I tke the snap ring off the opposite side? Help..... .
Dr.EVIL
10-06-2003 07:36:42
 Re: cub cadet 1250 hydro in reply to david, 10-05-2003 13:08:24
Do a search for a web site "ihcubcadet.com" They have frequently asked questions about that linkage plus several sponsors who can get You new or used parts.
