Tractor Talk Discussion Forum
Tractor Gas Pt II
ErnieD
10-07-2003 15:40:00
You are limited to 66 pounds of gasoling in a non specification container for road carriage. If you go over 66 pounds you best be trained and have a specifiction (ie UN) container or DOT stamp on your transportation tank.
Diesel fuel is higher flash point and rules are different.
rustyfarmall
10-08-2003 04:26:25
 Re: Tractor Gas Pt II in reply to ErnieD, 10-07-2003 15:40:00
If that is true, there are a lot of farmers and construction companies who are breaking the law every day.
ErnieD
10-08-2003 14:36:18
 Re: Re: Tractor Gas Pt II in reply to rustyfarmall, 10-08-2003 04:26:25
Check out the Northern Hydraulic catalog. They have pup fuel tanks for pu trucks. Disclaimer stating not DOT tested/stamped.
sammy the RED
10-07-2003 17:08:11
Ernie, For what state is this law ?
ErnieD
10-07-2003 17:55:51
 Re: Re: Tractor Gas Pt II in reply to sammy the RED, 10-07-2003 17:08:11
49 CFR; federal law. The same law that requires among other things the diamond hazard symbols (placards) on large trucks. Applies to all states, particularly confusion.
sammy the RED
10-07-2003 18:46:03
 Re: Re: Re: Tractor Gas Pt II in reply to ErnieD, 10-07-2003 17:55:51
Some Fed. Acts apply to interstate and some do not apply to intrastate.
