Tractor Talk Discussion Forum
Tires cracking
Archie
10-08-2003 16:26:39
Hello all. I have a set of rear tractor tires only seven years old and they are starting to weather crack. Sits in barn all time when not in use. Have tried stuff from local auto parts store but not much success. Any ideas. Thank you Archie
Archie
10-09-2003 16:33:17
 Re: Tires cracking in reply to Archie, 10-08-2003 16:26:39
Follow up. They are good year tires. I use the tractor about three hours a week. It is a fifty three model 40 john deere The original tires finally split past using. Maybe this set will last as long as i need it. Thank all of for the comments. Good luck to all. Archie
MapleStone
10-09-2003 09:39:15
I was told once that the best way to prevent tire cracks is USE THEM.
By flexing the ruber you prevent them from drying out and cracking. SO drive, boy drive! You never see cracked tires on a tractor that is used every day do you?
Other than that use the tire protectants that are available at retailers.
red
10-08-2003 16:58:24
try rubbing motor oilinto them once a week for three weeks then every month if it doesnt stop the cracking it will look nice
Doesn't oil rot rubber???
10-08-2003 17:06:43
 Re: Re: Tires cracking in reply to red, 10-08-2003 16:58:24
n/m
Dave_Id
10-08-2003 18:08:23
 Re: Re: Re: Tires cracking in reply to Doesn't oil rot rubber???, 10-08-2003 17:06:43
Oil eats Polycarbonate (Lexan) plastic, but I don't believe it does anything to rubber tires
Jim
10-08-2003 18:44:05
 Re: Re: Re: Re: Tires cracking in reply to Dave_Id, 10-08-2003 18:08:23
YES oil eats rubber, it may take a while but it will eat it.
arthur
10-09-2003 19:44:26
 Re: Re: Re: Re: Re: Tires cracking in reply to Jim, 10-08-2003 18:44:05
what air pressur are you keeping them at are you over pressuring them ??
kjm
10-08-2003 19:08:02
Go ahead and use the oil it wont hurt a thing. Oh by the way, did I say that I sell tires for a living?
dhermesc
10-09-2003 08:31:43
 Re: Re: Re: Re: Re: Re: Tires cracking in reply to kjm, 10-08-2003 19:08:02
What brand of tires are they? Have they ever been exposed to some chemical that would have damaged them? We have tractor tires that sit outside year round that haven't suffered that kind of damage. Are you using something like Armour All (will cause a lot of damage)?
PS don't use oil!
