Tractor Talk Discussion Forum
Diesel fuel circlation
thebigron
10-09-2003 20:25:14
Been wondering if anyone might have a handle on how many times does diesel fuel circulate thru the system of say a 10 gallon tank burning 1 gallon per hour? Just for the first hour, as of course it would go thru more times as the fuel is less and less.
Ray,IN
10-09-2003 21:00:13
 Re: Diesel fuel circlation in reply to thebigron, 10-09-2003 20:25:14
My diesel tractors do not have a return line to the fuel tank, making circulation impossible. The engine uses the fuel required by throttle setting.
twopop
10-10-2003 06:59:21
 Re: Re: Diesel fuel circlation in reply to Ray,IN, 10-09-2003 21:00:13
if you will check further you will find that your diesels circulate fuel thru the pump,excess fuel is returned from the injectors to the pump
Deas Plant.
10-10-2003 12:17:45
 Re: Re: Re: Diesel fuel circlation in reply to twopop, 10-10-2003 06:59:21
Hi, Twopop. Not all diesel systems re-circulate their excess fuel through the pump. There are quite a few that send the excess back to the tank.
Hope this helps.
You have a wonderful day. Best wishes. Deas Plant.
