Tractor Talk Discussion Forum
Re: Diesel Engine Problems
rhudson
10-13-2003 05:10:48
hi Douginva,
gona need a little more info to be specific. but i guessin that you have a problem on the low pressure side of the fuel system. stopped up or flooded with water inlet at the tank, crushed line between the tank to the injector pump, nonworking low pressure pump(thats the one that looks like a regular gas engine pump), stopped up or wet fuel filter. if you have a fuel pressure gauge check for flow and pressure at the the outlet of the low fuel pump (should be around 5 to maybe 7 psi)
not famuliar with longs, but think most diesel systems are generic.
