Tractor Talk Discussion Forum
Piston rings stuck in groove
Bruce Pierce
10-14-2003 18:25:27
I have an engine I am working on and one of the pistons has all of the rings stuck into the grooves.
Is there some "home remedy" that I could soak the piston in to dissolve the carbon?
Thanks
Bruce Pierce
Murray, KY
TO35Man
10-15-2003 16:41:17
 Re: Piston rings stuck in groove in reply to Bruce Pierce, 10-14-2003 18:25:27
I use wurth brake clean...unsticks them in minutes.
goodluck..
TO35
John Walls GA
10-15-2003 15:03:30
Bruce:
If there is a NAPA auto parts store near you, go and get a can of Sea Foam. This product was developed to remove carbon from two-stroke engines. Pour it onto your rings and let it soak overnite. Come back and give them a tap or two with a small hammer and they should come loose. If not, soak them some more. NAPA also has this product in an aerosol can. It is called Deep Creep
stan
10-15-2003 08:57:13
Unless the rings are real hard to get I would break them out and but new ones.
Nebraska Cowman
10-15-2003 04:15:56
I tap the rings gently with the wooden wire brush handle and spray them with Blaster or WD40. Sometimes they still break and then you can buy new ones. I have had good luck finding used rings or broken sets.
Gene Davis(Ga.)
10-14-2003 18:35:13
I have had pretty good luck spraying with penetrating oil and choke cleaners to loosen carbon buildup. Gene
