Tractor Talk Discussion Forum
John Deere 40 - ignition coil
Lance
10-15-2003 20:48:56
I am pretty sure my coil is kaput. I have replaced all other ignition components and no spark. I think it is the original Delco-Remy coil! Can I replace it with a universal 6 volt coil? Please advise. Thanks for any help. Lance in Brenham, TX.
buickanddeere
10-16-2003 19:04:53
 Re: John Deere 40 - ignition coil in reply to Lance, 10-15-2003 20:48:56
Wire the coil with the positive post to the points to match the positive ground connection at the battery. More voltage at the coil secondat and it's easier for the spark to jump from the sparkplug center tip to the outer electrode than vice versa.
ralph
10-16-2003 04:29:25
check the fuse first. ralph
Lance
10-16-2003 06:18:53
 Re: Re: John Deere 40 - ignition coil in reply to ralph, 10-16-2003 04:29:25
I have voltage at the coil.
Andy
10-16-2003 04:16:39
Yep, any 6 volt coil will work. I replaced mine with an aftermarket one and have had no problems...
