Tractor Talk Discussion Forum
international backhoe hydrostatic won't move forw
ronnie
10-17-2003 20:34:08
Looking for circuit diagram or any help on a 2400 IH backhoe.. machine quit moving forward or rev all of the sudden. hope just a broken oring or stuck checkvavle but don't know where to test for pressure..
any help apperciated
geok
10-18-2003 05:52:34
 Re: international backhoe hydrostatic won't move f in reply to ronnie, 10-17-2003 20:34:08
On the top of the transmission cover there is a small block with a coiled line connected to one side of it. On the opposite side there are two hex head plugs. You can check pressure there for foward and reverse. Front plug is reverse and rear plug is forward. With range seletor in high, you should get a reading of 5500 psi for both direction. Are you certain that your hi low range seletor is not in neutral?
R. Marg
10-17-2003 20:58:06
the cat 950 that a friend of mine leaves at my house does that some times when the fliud level gets low have you checked that?
