Tractor Talk Discussion Forum
Staight pipes on gas tractors
Ken
10-18-2003 05:59:50
Is there any problem other than noise of running a staight pipe on a gasoline tractor such as a Farmall 460? We run them on all our diesel tractors but didnt know if gas was differnt as far as needing the backpressure.
Kens640
10-30-2003 19:38:30
 Re: Staight pipes on gas tractors in reply to Ken, 10-18-2003 05:59:50
Is there a problem with running it with a muffler so you don't have to worry ? Think about that if you catch a hayfield on fire with a straight thru pipe .Use the knowledge God gave you on that decision .
Nerve Damaged
10-19-2003 18:52:25
Say Whatttt?
tractor dan
10-19-2003 15:49:07
i had a 460 utility gas that i ran strait pipe on ran much better than it did with muffler with muffler on the governor sureged alot with strait pipe it just came to life plus a 3and ahalf foot pipe on that six cylinder sounded great
arthur
10-18-2003 21:04:46
why not put header's onthen tune the exhaust like a race car more power also.
K.B.
10-18-2003 20:00:07
I would recommend that you keep a muffler on that one. Not that a straightpipe hurts the engine, but those IH gas six-cylinders will really ring your ears.
rustyfarmall
10-18-2003 06:16:03
Won't hurt a thing other than your ears.
Jerry
10-18-2003 07:18:42
 Re: Re: Staight pipes on gas tractors in reply to rustyfarmall, 10-18-2003 06:16:03
I run with straight pipes but I still remember the time when I split the manifold on my 1954 chevrolet 6 cylinder and need a valve job within several weeks.
Allan
10-18-2003 07:58:42
 Re: Re: Re: Staight pipes on gas tractors in reply to Jerry, 10-18-2003 07:18:42
Jerry,
Bingo!!!
I was wondering if anyone was going to bring this up.
A valve will warp whether it is from burning diesel or from gasoline.
I would caution anyone who is running straight pipes and pulling hard, to definitely let the thing idle for a minute or two to cool the valves before shutting down.
Everything is fine as long as the engine is running, but after shutdown, if the outside air temp/wind is just right, that cold air coming back up that pipe and hitting that near 2000-degree valve can cause a stem to ‘pull’ if it is hanging open.
It is a good idea to let ‘em idle a few minutes prior to shutdown, even with a muffler installed.
Just a thought,
Allan
rustyfarmall
10-18-2003 13:21:57
 Re: Re: Re: Re: Staight pipes on gas tractors in reply to Allan, 10-18-2003 07:58:42
Guess I had forgotten that could happen, but it would happen only if the engine was working hard and you immediately shut it off. Not a good idea for any engine, with, or without, a muffler.
