Tractor Talk Discussion Forum
nuffield 4/65
johno
10-18-2003 12:08:14
after removing contaminated hydraulic can i substitute with deiseloil shortterm to run and remove impurities , thanks
richard
10-18-2003 16:06:04
 Re: nuffield 4/65 in reply to johno, 10-18-2003 12:08:14
I have done this in the past,clean the suction strainer and fill with diesel run for 10 min or so with the wheels jacked to slosh it around the casing but to avoid loading.Drain, clean strainer again,if satisfied fill with correct grade of oil,otherwise repeat untill you are.
