Tractor Talk Discussion Forum
1948 h with delco distributor
yooper
10-19-2003 19:17:27
Help - looking for help finding the correct cap and rotor for my H with a delco distributor. someone out there listed the napa numbers I nededed and I cant remember where they are. The distributor number is 11114111. My local napa store can't find the right part. This H was converted from distilates to gas and is 6 volt
Larry in CO
10-19-2003 20:00:01
 Re: 1948 h with delco distributor in reply to yooper, 10-19-2003 19:17:27
yooper,
Here are the numbers you need for all the parts - at least that's what my '46 H with a Delco distributor needed.
The distributor cap is NAPA part number RR145.
The rotor is NAPA part number RR83.
The points set is NAPA part number CS763A.
The condensor is NAPA part number RR174.
HTH,Larry
yooper
10-19-2003 20:48:07
 Re: Re: 1948 h with delco distributor in reply to Larry in CO, 10-19-2003 20:00:01
thanks-I will check out these and see if they are the right ones
